Is there a way to disable AutoNAT IP detection on a Kubo node?
For example, I’m running a Kubo node on fly.io and because fly.io is doing some weird IP stuff (outgoing requests appear to be originating from a different IPv4), the externally observable IP is different to the one that its reachable on.
I tried setting the following config:
ipfs config AutoNAT.ServiceMode 'disabled'
However, ipfs id still returns the wrong public IPs in the list of addresses.
I am pretty confident this is the source of the problem because when I look at the observable public IP of the Kubo container it’s the same wrong one that shows up in the list of addresses:
/ # wget -qO- ifconfig.me
145.40.93.179
/ # ipfs id
"Addresses": [
"/ip4/145.40.93.179/tcp/4001/p2p/12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh",
"/ip4/145.40.93.179/udp/4001/quic-v1/p2p/12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh",
"/ip4/145.40.93.179/udp/4001/quic/p2p/12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh",
However, I am certain that 145.40.93.179 is not the correct public IP.
