galacteek version 0.4.34 was released, you can download it here
Release notes
Filesharing from the files workspace
Support for detached go-ipfs instances (the IPFS daemon will keep running after you exit). Enable it in the settings with the Keep IPFS daemon running option
MFS file renaming in the filemanager
Fix a bug with ipfs-search filters
Encrypted pubsub topics
Support emojis in markdown with unimoji
