Getsockopt: connection refused ipfshttp.go when run ipfs cluster in ubutu 16.04
I created a private ipfs cluster in ubuntu 16.04, but when i run peers, it notification error:
18:21:50.343 ERROR ipfshttp: error getting:Get http://127.0.0.1:5001/api/v0/repo/stat: dial tcp 127.0.0.1:5001: getsockopt: connection refused ipfshttp.go:695
Can you help me ?
It would seem you are not running IPFS (if you are starting both a the same time this error may occur (since ipfs takes a while longer to boot up, but is not critical).
thank you, it worked
