Go-ipfs "Connection refused": Setting up my first node
I’m trying to set up an IPFS node so that I can use it as a gateway.
To do that, I’ve followed this guide: The definite guide to your high-performance IPFS Gateway | DSLA Protocol Blog
It runs on a google cloud virtual machine with Debian.
However, when I try to test connectivity and CORS I get the following error log:
* Expire in 0 ms for 6 (transfer 0x55b7d7b60fb0)
*   Trying 0.0.0.0...
* TCP_NODELAY set
* Expire in 200 ms for 4 (transfer 0x55b7d7b60fb0)
* connect to 0.0.0.0 port 5001 failed: Connection refused
* Failed to connect to 0.0.0.0 port 5001: Connection refused
* Closing connection 0
curl: (7) Failed to connect to 0.0.0.0 port 5001: Connection refused
Test command:
curl -v -H "Origin: http://test.com" \
-H "Access-Control-Request-Method: POST" \
-H "Access-Control-Request-Headers: X-Requested-With" \
http://0.0.0.0:5001/api/v0/swarm/peers
HTTPHeaders section of my IPFS config file:
"HTTPHeaders": {
      "X-Requested-With",
      "Access-Control-Expose-Headers",
      "Range"
   ],   "Access-Control-Expose-Headers": [
      "Location",
      "Ipfs-Hash"
   ],   "Access-Control-Allow-Methods": [
      "POST",
      "GET"
   ],   "Access-Control-Allow-Origin": [
   ],   "X-Special-Header": [
      "Access-Control-Expose-Headers: Ipfs-Hash"
},"RootRedirect": "",
"Writable": true,
"PathPrefixes": [],
"APICommands": []
nginx.conf
user       manage;  ## Default: nobody
worker_processes  5;  ## Default: 1
worker_rlimit_nofile 8192;
events {
  worker_connections  4096;  ## Default: 1024
http {
  include    /etc/nginx/fastcgi.conf;
  index    index.html index.htm index.php;
  default_type application/octet-stream;
  log_format   main '$remote_addr - $remote_user [$time_local]  $status '
    '"$request" $body_bytes_sent "$http_referer" '
    '"$http_user_agent" "$http_x_forwarded_for"';
  sendfile     on;
  tcp_nopush   on;
  server_names_hash_bucket_size 128; # this seems to be required for some vhosts
  server {
    server_name example.com; # managed by Certbot
    location /ipfs {
        proxy_pass http://localhost:8080;
        proxy_set_header Host $host;
        proxy_cache_bypass $http_upgrade;
        allow all;
    location / {
        proxy_pass http://localhost:5001;
        deny all; # <- Deny other traffic
    listen [::]:443 ssl ipv6only=on; # managed by Certbot
    listen 443 ssl; # managed by Certbot
    ssl_certificate /etc/letsencrypt/live/example.com/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/example.com/privkey.pem; # managed by Certbot
    include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
    ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
    if ($host = recall.network) {
        return 301 https://$host$request_uri;
    } # managed by Certbot
    listen 80 default_server;
    listen [::]:80 default_server;
    server_name recall.network;
    return 404; # managed by Certbot
See
You need to use your actual address.
