Hi I wanna contribute but where to start?
Is there some (general) documentation about the code. I’ve seen a tutorial but that wasn’t what I expected. I code in NodeJS, I can do testing too.
Thanks Rob :slight_smile:
Here you can find the overview of whole IPFS project.
Here you can find the technical specifications for IPFS Stack(Libp2p, IPLD etc)
Also I am working on a ton of cool projects. You can check them out on Github, and our website. I recently posted what I am doing right now. Feel free to check it out.
Cheers!
I guess for JS a starting point would be here: https://github.com/ipfs/community/blob/master/CONTRIBUTING_JS.md :slight_smile:
Ok I checked the resources but I mainly mean some issues that I could get started with?
There are a few places to start from:
Here is how you can start: Intro
Here is a list of all the projects going on.
First, see where you want to contribute.
If you aren’t able to decide, you can start here:
js-ipfs: you can see the “Want to Contribute” section here
Also, I am maintaining an unofficial Javascript implementation of IPFS Cluster API. You can check out the issues
