How can I call findProvs and findPeer from the client's browser?
Hello, I am building a project which visualizes the trajectory of DHT queries as you search for and locate provider records:
https://ipfs-globe.netlify.app/
GitHub - dwarkeshsp/ipfs-globe’
Right now, I’m using one of IPFS’s delegate nodes to run findProvs and findPeer, the two IPFS functions I need for this project. This means the request is not originating from the client.
My question: Is there a way in which I can run findProvs and findPeer from the client’s computer via the browser, either by connecting to their daemon or by using the Brave integration, or something else?
When I run:
const response = await fetch("http://127.0.0.1:5001/api/v0/version", {
  method: "POST",
  mode: "no-cors",
console.log(await response.text());
I get the error:
POST http://127.0.0.1:5001/api/v0/version 403 (Forbidden)
How do I get permission to access a user’s daemon through the HTTP API? BTW, I added mode: "no-cors" because before doing that, I was getting a cors error.
Thanks!
I still haven’t gotten a response on this yet. Does anyone know how I can get permission to access a user’s daemon through the HTTP API? Thanks a lot!
You can use the http client module - ipfs-http-client - npm - don’t forget to enable CORS headers in your daemon config.
Once you can connect successfully, see the DHT functions in the core-api docs for how to invoke findProvs and findPeer.
