I’m trying to run simple DHT commands on nodejs but it returns the following error:
(node:17640) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'findPeer' of undefined
The simple code i’m using is:
const node = await IPFS.create()
const result = await node.dht.findPeer( peerId)
I’m not having problems with other commands such as SWARM PEERS
Thanks for support
Sorry to hear you are having problems - what version of ipfs are you using?
I’m using the 6.14.4. Also I’ve noticed that the ipfs.swarm.peers return very few peers compared to the same command executed with ipfs-http-client
6.14.4 of of what? The latest js-ipfs version is 0.42.0.
Oh sorry, looking with npm I can see that i’m using ipfs v0.42.0 and js-ipfs 0.0.301
The DHT is not enabled in js-ipfs by default, you have to explicitly enable it with:
const node = await IPFS.create({
libp2p: {
config: {
dht: {
enabled: true
Though there’s a regression in the current js-ipfs release that means you can’t enable it, even with the above config (will be fixed by ipfs/js-ipfs#2976.
At any rate the DHT is still considered experimental so will probably cause your node to fall over after a while.
Ok thank you. I tried but as expected it didn’t work. I solved by switching to ipfs-http-client where the same command works
