Ipfs.pin.remote.service.add undefined... help please!
Hello!
Any help on this would be really appreciated - thanks :smiley:
Using js-ipfs, in node.js.
installed with npm install --save ipfs
I’m continually getting the following error when trying to add a remote pinning service.
(node:9004) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'service' of undefined
using the line:
const node = await IPFS.create();
await node.pin.remote.service.add(PINNING_SERVICE_NAME, {
	endpoint: PINNING_SERVICE_ENDPOINT,
	key: PINNING_SERVICE_API_KEY
Note, the script successfully create()s a new ipfs node, and can node.add() and node.pin.add() without problem. Any ideas why the remote service part is undefined? Full error below.
Thank you very much for your help!
at main (c:\Users\me\myproject\pinRemote.js:38:24)
at emitUnhandledRejectionWarning (internal/process/promises.js:168:15)
at processPromiseRejections (internal/process/promises.js:247:11)
at processTicksAndRejections (internal/process/task_queues.js:94:32)
(node:9004) TypeError: Cannot read property 'service' of undefined
(node:9004) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
at emitDeprecationWarning (internal/process/promises.js:180:11)
at processPromiseRejections (internal/process/promises.js:249:13)
Are you sure this feature is ready in ‘js-ipfs’ already ?
see these:
Thanks for the links - you’re quite right.
Confirmed here too:
I was confused with pin.remote.service appearing in the js-ipfs docs: js-ipfs/PIN.md at master · ipfs/js-ipfs · GitHub
But not in the js-ipfs packages: js-ipfs/packages/ipfs-core/src/components/pin at master · ipfs/js-ipfs · GitHub
Honestly I’m still new to the way all of this is structured - thanks for your help with understanding it.
I have another question if you wouldn’t mind:
What is the purpose of the /docs/ folder, and why would it differ from what is provided in /packages/ ?
Thanks
