I’ve been analyzing the js ipfs source codes to understand how exactly delegated routing works. It turns out that js ipfs uses delegated routing by default, which means whenever I call IPFS.cat(), I send an http request to a delegated routing node that will perform DHT querying and propagation on my behalf and return the contents back to me so I can display them. What confuses the heck out of me for a few weeks is how exactly those delegated routing nodes alter my node’s local directory upon returning a response. I am positive that the cat method creates a new local directory with the returned contents, since while analyzing the source code for ipfs.cat(), I realized that it calls repo.blocks.get(CID, options), and during that process, fs-datastore.get(cid) is called, which uses the OS module to append my node’s local directory to the CID of the file to be fetched. So it only seems logical that either the node-fetch module on my local node saves the file on my local directory so it can be accessed by fs-datastore.get() or that the delegated routing node somehow remotely saves the files on my local directory after figuring out its path.
function fetch(url, opts) {
//native-fetch method
//This method should fetch an ipfs file from other peers and then
//save it to the local directory
// allow custom promise
if (!fetch.Promise) {
throw new Error('native promise missing, set fetch.Promise to your favorite alternative');
Body.Promise = fetch.Promise;
// wrap http.request into fetch
return new fetch.Promise(function (resolve, reject) {
// build request object
const request = new Request(url, opts);
const options = getNodeRequestOptions(request);
const send = (options.protocol === 'https:' ? https : http).request;
const signal = request.signal;
let response = null;
const abort = function abort() {
let error = new AbortError('The user aborted a request.');
reject(error);
if (request.body && request.body instanceof Stream.Readable) {
destroyStream(request.body, error);
if (!response || !response.body) return;
response.body.emit('error', error);
if (signal && signal.aborted) {
abort();
return;
const abortAndFinalize = function abortAndFinalize() {
abort();
finalize();
// send request
const req = send(options);
console.log("node-fetch req(http.request() return value, send() return value): ", req)
let reqTimeout;
if (signal) {
signal.addEventListener('abort', abortAndFinalize);
function finalize() {
req.abort();
if (signal) signal.removeEventListener('abort', abortAndFinalize);
clearTimeout(reqTimeout);
if (request.timeout) {
req.once('socket', function (socket) {
reqTimeout = setTimeout(function () {
reject(new FetchError(`network timeout at: ${request.url}`, 'request-timeout'));
finalize();
}, request.timeout);
req.on('error', function (err) {
reject(new FetchError(`request to ${request.url} failed, reason: ${err.message}`, 'system', err));
if (response && response.body) {
destroyStream(response.body, err);
finalize();
fixResponseChunkedTransferBadEnding(req, function (err) {
return;
/* c8 ignore next 18 */
if (parseInt(process.version.substring(1)) < 14) {
// Before Node.js 14, pipeline() does not fully support async iterators and does not always
// properly handle when the socket close/end events are out of order.
req.on('socket', function (s) {
s.addListener('close', function (hadError) {
// if a data listener is still present we didn't end cleanly
const hasDataListener = s.listenerCount('data') > 0;
// if end happened before close but the socket didn't emit an error, do it now
if (response && hasDataListener && !hadError && !(signal && signal.aborted)) {
const err = new Error('Premature close');
err.code = 'ERR_STREAM_PREMATURE_CLOSE';
response.body.emit('error', err);
req.on('response', function (res) {
const headers = createHeadersLenient(res.headers);
// HTTP fetch step 5
if (fetch.isRedirect(res.statusCode)) {
// HTTP fetch step 5.2
const location = headers.get('Location');
// HTTP fetch step 5.3
const locationURL = location === null ? null : resolve_url(request.url, location);
// HTTP fetch step 5.5
switch (request.redirect) {
case 'error':
reject(new FetchError(`uri requested responds with a redirect, redirect mode is set to error: ${request.url}`, 'no-redirect'));
finalize();
return;
case 'manual':
// node-fetch-specific step: make manual redirect a bit easier to use by setting the Location header value to the resolved URL.
if (locationURL !== null) {
// handle corrupted header
try {
headers.set('Location', locationURL);
} catch (err) {
// istanbul ignore next: nodejs server prevent invalid response headers, we can't test this through normal request
reject(err);
break;
case 'follow':
// HTTP-redirect fetch step 2
if (locationURL === null) {
break;
// HTTP-redirect fetch step 5
if (request.counter >= request.follow) {
reject(new FetchError(`maximum redirect reached at: ${request.url}`, 'max-redirect'));
finalize();
return;
// HTTP-redirect fetch step 6 (counter increment)
// Create a new Request object.
const requestOpts = {
headers: new Headers(request.headers),
follow: request.follow,
counter: request.counter + 1,
agent: request.agent,
compress: request.compress,
method: request.method,
body: request.body,
signal: request.signal,
timeout: request.timeout,
// HTTP-redirect fetch step 9
if (res.statusCode !== 303 && request.body && getTotalBytes(request) === null) {
reject(new FetchError('Cannot follow redirect with body being a readable stream', 'unsupported-redirect'));
finalize();
return;
// HTTP-redirect fetch step 11
if (res.statusCode === 303 || (res.statusCode === 301 || res.statusCode === 302) && request.method === 'POST') {
requestOpts.method = 'GET';
requestOpts.body = undefined;
requestOpts.headers.delete('content-length');
// HTTP-redirect fetch step 15
resolve(fetch(new Request(locationURL, requestOpts)));
finalize();
return;
// prepare response
res.once('end', function () {
let body = res.pipe(new PassThrough$1());
const response_options = {
url: request.url,
status: res.statusCode,
statusText: res.statusMessage,
headers: headers,
// HTTP-network fetch step 12.1.1.3
const codings = headers.get('Content-Encoding');
// HTTP-network fetch step 12.1.1.4: handle content codings
// in following scenarios we ignore compression support
// 1. compression support is disabled
// 2. HEAD request
// 3. no Content-Encoding header
// 4. no content response (204)
// 5. content not modified response (304)
if (!request.compress || request.method === 'HEAD' || codings === null || res.statusCode === 204 || res.statusCode === 304) {
response = new Response(body, response_options);
resolve(response);
return;
// For Node v6+
// Be less strict when decoding compressed responses, since sometimes
// servers send slightly invalid responses that are still accepted
// by common browsers.
// Always using Z_SYNC_FLUSH is what cURL does.
const zlibOptions = {
flush: zlib.Z_SYNC_FLUSH,
finishFlush: zlib.Z_SYNC_FLUSH
// for gzip
if (codings == 'gzip' || codings == 'x-gzip') {
body = body.pipe(zlib.createGunzip(zlibOptions));
resolve(response);
return;
// for deflate
if (codings == 'deflate' || codings == 'x-deflate') {
// handle the infamous raw deflate response from old servers
// a hack for old IIS and Apache servers
const raw = res.pipe(new PassThrough$1());
raw.once('data', function (chunk) {
// see http://stackoverflow.com/questions/37519828
if ((chunk[0] & 0x0F) === 0x08) {
body = body.pipe(zlib.createInflate());
} else {
body = body.pipe(zlib.createInflateRaw());
resolve(response);
return;
// for br
if (codings == 'br' && typeof zlib.createBrotliDecompress === 'function') {
body = body.pipe(zlib.createBrotliDecompress());
resolve(response);
return;
// otherwise, use response as-is
resolve(response);
writeToStream(req, request);
In the node-fetch module’s fetch source code, there doesn’t seem to be anywhere that saves the response to my local directory, let alone figure out the local directory with the OS module. While it seems unlikely that the remote delegated routing node access my local directory and saves the file remotely, if it’s possible method, I’d like to know how exactly this whole file saving process works that I’ve been struggling to understand for weeks.
