How do I see how much disk space a recursive pin is consuming?
I know the recursive pin its self isn’t using much data at all, but I mean all of the indirect hashes that it points to all added to gather.
The way I see it is that individual hashes aren’t that important. I don’t think I have even manually pinned a hash that wasn’t recursive. So if any of my pins are taking up too much disk space I would want to look at the recursive hashes that are taking up the most room and see if I really need them. Not sure how to do this though. :thinking:
ipfs object stat HASH
Will get you the recursive size of an object which will give you an approximate idea of how much disk space the pinned object is taking.
Thanks! Works like a charm.
I was searching around through the documentation and everything in ipfs object was rather arcane. It didn’t occur to me that
Get stats for the DAG node named by < key >.
Was exactly what I was looking for :sweat_smile:
