Scenario:
We have a running local daemon.
A client wasm app in the browser requires an orbit-db connection. To create new OrbitDB instance we need coreapi.CoreAPI param.
// NewOrbitDB Creates a new OrbitDB instance with default access controllers and store types
func NewOrbitDB(ctx context.Context, i coreapi.CoreAPI, options *NewOrbitDBOptions) (iface.OrbitDB, error) {
We can not create a new node because ipfs can not use wasm target.
node, err := core.NewNode(ctx, nodeOptions)
if err != nil {
return nil, err
// Attach the Core API to the constructed node
return coreapi.NewCoreAPI(node)
We can create a new shell though:
// Where your local node is running on localhost:5001
sh := shell.NewShell("localhost:5001")
There is a method to get the peer id:
sh.ID()
Is it possible to get *core.ipfsNode instance from the shell?
P.S. It was suggested to use GitHub - ipfs/go-ipfs-http-client: Go-IPFS API implementation over HTTP API instead.
It seems to be working in the following way:
c, err := client.NewURLApiWithClient("localhost:5001", &http.Client{})
if err != nil {
panic(fmt.Errorf("failed to connect to local api: %s", err))
