From @border0464111 on Tue Aug 02 2016 18:01:29 GMT+0000 (UTC)
I was trying to embed some video and in a webpage, They work well if I call them directly but not working once imbeded if they are not on my local cache.
So I narrowed the problem to a point where the following query (wich replicate query made by my webpage) will never receive a response and hang eternaly:
curl ‘http://127.0.0.1:8080/ipns/QmdyyqsCJCyV4swTu7GsuCKfD3kZkBkiRriDi1KiWFzk7m/100K%20Subscribers%20Special%20Compilation%20_%204H%20Party%20Music%20_%20EDM,%20NCS,%20Dubstep-iJ05N8pCI0E.webm’ -H ‘Referer: http://127.0.0.1:8080/ipfs/QmVMML5x3ZhDCA9zNyWmm9dXvKJ9tMh7PaHWYSDjTLnTRn/’ -H ‘Accept-Encoding: identity;q=1, *;q=0’ -H ‘User-Agent: Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Ubuntu Chromium/51.0.2704.79 Chrome/51.0.2704.79 Safari/537.36’ -H ‘Range: bytes=390496256-’ --compressed
If I change to ‘Range: bytes=9000-’ or remove it completely. The data will start to flow in.
Im supposing file lenght is smaller then 390496256. ( But due to an other bug, Im sudently unable to resolve de IPNS anymore… )
In any case, what ever is the reason for this. Gateway should return HTTP 416 status code(Requested Range Not Satisfiable) instead of hanging.
Copied from original issue: HTTP request header 'Accept-Ranges' does does not respond in some case · Issue #35 · ipfs-inactive/support · GitHub
