Importing .car doesn't work
Hello. I am trying to import .car in 1,000 files(202MB) in my IPFS node, but it doesn’t work. When I import 10 files, it works. Is there a limit to the amount of data I can import?
Can you add some more details about what exactly you’re doing and what the error is?
Thank you for your response! This topic is solved!
