The directory is a mounted directory, a share from another computer, mounted into the home directory. It seems to go through and add everything. It showed progress and amount of TB, listed all the files/directories with CIDs and stuff. But when I try to pull any of them up on another peer - I don’t get anythig. IPFS-Desktop on another computer says “The current link isn’t a file, nor a directory. Try to inspect it instead.”
OK, I had to specify a specific IP to bind to. I then started the daemon back up and now it seems to be working! Still having trouble getting the IPFS Desktop to connect to the daemon though. I don’t really need to use the Desktop, thought it would be nice to get it to work and know how to use both at the same time.
