I have an IPFS node and a private IPFS cluster running in containers. It works well as it is but as soon as I try to have a VPN WireGuard (ProtonVPN) sidecar container to it, it does not seem to work anymore.
When the sidecar is enabled, I see that my true IP is indeed not disclosed anymore, and it’s replaced by 2-3 other IPs.
The IPFS container shows this kind of error sometime: ERROR autorelay autorelay/autorelay.go:84 failed to start relay finder {"error": "relayFinder already running"}
The IPFS cluster shows more frequent errors:
cluster | 2023-03-26T01:03:09.304Z INFO cluster ipfs-cluster/cluster.go:598 reconnected to xxxxxxxxxxxxxxxxxxxx
cluster | 2023-03-26T01:03:36.044Z INFO cluster ipfs-cluster/cluster.go:598 reconnected to xxxxxxxxxxxxxxxxxxxx
cluster | 2023-03-26T01:04:22.049Z INFO cluster ipfs-cluster/cluster.go:598 reconnected to xxxxxxxxxxxxxxxxxxxx
cluster | 2023-03-26T01:05:07.059Z INFO cluster ipfs-cluster/cluster.go:598 reconnected to xxxxxxxxxxxxxxxxxxxx
cluster | 2023-03-26T01:05:46.796Z INFO cluster ipfs-cluster/cluster.go:598 reconnected to xxxxxxxxxxxxxxxxxxxx
cluster | 2023-03-26T01:05:54.778Z INFO crdt go-ds-crdt@v0.3.10/crdt.go:891 DAG repair finished. Took 3m19s
cluster | 2023-03-26T01:05:54.778Z ERROR crdt go-ds-crdt@v0.3.10/crdt.go:510 error getting node for reprocessing xxxxxxxxxxxxxxxxxxxx: context deadline exceeded
cluster | 2023-03-26T01:06:12.529Z INFO cluster ipfs-cluster/cluster.go:598 reconnected to xxxxxxxxxxxxxxxxxxxx
I also tried only announcing the endpoint IP of my WireGuard config.
On the ProtonVPN side, I have enabled a bunch of features that without being an expert I thought could help with port forwarding:
# Bouncing = 9
# NetShield = 0
# Moderate NAT = on
# NAT-PMP (Port Forwarding) = on
# VPN Accelerator = off
Is it a lost cause? Or running an IPFS node behind a WIreGuard VPN is supposed to smooth?
Also it’s worth noting that I used https://check.ipfs.network/ to check the status of my node and the only reported failure is the latest one:
✔ Successfully connected to multiaddr
✔ Found multiaddrs advertised in the DHT:
# All multiaddr without my true IP
✔ Found multihash advertised in the dht
❌ There was an error downloading the CID from the peer: transient connection to peer
My experience is that any kind of VPN prevents port mapping, so IPFS has to rely on relay v2 for establishing connections. That works ok for simple stuff, but the second you try to exchange blocks, it needs to use hole punching to establish a direct connection, and that rarely (never?) works across a VPN (latency issues prevent sync?).
Reading the doc it seems like hole punching is already enabled by default but I just wanted to make sure that are no default ipfs config I could try to play with to increase the success rate here?
I’m not familiar with the details of how wireguard works. See if there is any way to configure static port mapping to a node, that would solve the problem.
I gave it a try with a VPN provider supporting static port forwarding. I can call ipfs swarm connect using the exit VPN IP and the configured static port and the connection works well.
Now I have an issue to announce properly this IP/port from the IPFS node.
I followed the doc and used ipfs config --json Addresses.AppendAnnounce to add the correct multiaddr with the VPN IP and port.
Upon start, ipfs id correctly adds those to the Addresses key but after a few seconds the set multiaddr just disappears. Not sure the reason for that since ipfs swarm connect works well.
It turns out the ipfs swarm connect command worked for a wrong reason and once behind the vpn I can’t make it work. I always hit a Connection refused error. I also tried with telnet as well.
I am quite sure the port is correctly forwarded because when I run a port checker binary, it works well: docker-compose exec ipfs /bin/sh -c "wget -qO port-checker https://github.com/qdm12/port-checker/releases/download/v0.3.0/port-checker_0.3.0_linux_amd64 && chmod +x port-checker && ./port-checker -port 4322"
I have the impression ipfs is not listening on my port 4322 but I dont know the reason. I also tried to add it to the Swarm with:
You’re forgetting one important thing, a VPN is a NAT router. This means that, while your node is listening on port 4322 on the LAN, the VPN is probably listening on a different port on its public IP address. That’s the port you need to announce
I configured the VPN to listen to that port on the public IP address (4322) and this same port is forwarded to the container.
I already checked it with port-checker. It runs a small server in the ipfs container and I have been able to access it via the VPN public IP and the same port as above.
An alternative fix in my config would have been to redirect 4322 to 4001 within the container (4322:4001), so the ipfs announce 4322 but listen only on 4001.
But the other fix by editing Addresses.Swarm works as good.
Maybe a question for you: when adding a multiaddr to Addresses.AppendAnnounce, is it expected for ipfs to also listen to it or is it only to announce and so listening is always and only done with Addresses.Swarm?
Ok, thanks. It makes perfects sense to me, and it’s what I ended up understanding. I think the original confusion was coming from the difference in between announcing and listening.
