I am trying to understand the following:
I should run IPFS daemon before running the Cluster.
In the case of 2 peers, do I need to connect both IPFS daemons or if I provide them in the trusted peers’ list, the Cluster will manage to connect them?
The trusted peers list is for cluster peer IDs, not for IPFS daemons. The ability for the IPFS daemons to connect to each other will depend on their need and setup, but they might be able to autodiscover themselves on a LAN or via the main DHT if they are on the public network.
If you actually meant the IPFS Cluster daemons, they will try to autodiscover each others on LAN (using mdns like IPFS). Otherwise you need to provide full multiaddresses in the peerstore file or in the peer_addresses setting in the service.json configuration, as documented here: https://cluster.ipfs.io/documentation/deployment/setup/#the-peerstore-file
