Hi Team,
We have deployed a multi host private network using docker based IPFS cluster implementation. Both nodes are working fine individually but they are not able to connect to each other. We are getting this error while bootstrapping IPFS cluster node from second machine’s cluster node:
ERROR cluster ipfs-cluster/cluster.go:1049 failed to find peers: failed to find any peer in table
ERROR service ipfs-cluster-service/daemon.go:264 bootstrap to /ip4/[node-public-IP]/tcp/9400/p2p/[CLUSTER-PEER-ID] failed: failed to find peers: failed to find any peer in table
We have defined 9400 as the external port for our IPFS cluster node replacing 9096.
And, after listing peers from our cluster node using
ipfs-cluster-ctl peers ls
we are getting 0 other peers.
