2021-10-11T13:26:34.563Z INFO service ipfs-cluster-service/daemon.go:46 Initializing. For verbose output run with "-l debug". Please wait...
2021-10-11T13:26:34.566Z DEBUG service ipfs-cluster-service/lock.go:36 checking lock
2021-10-11T13:26:34.566Z DEBUG service ipfs-cluster-service/lock.go:54 ipfs-cluster-service execution lock acquired
2021-10-11T13:26:34.576Z INFO badger badger@v1.6.2/logger.go:46 All 3 tables opened in 1ms
2021-10-11T13:26:34.578Z INFO badger badger@v1.6.2/logger.go:46 Replaying file id: 0 at offset: 1918
2021-10-11T13:26:34.578Z INFO badger badger@v1.6.2/logger.go:46 Replay took: 2.778µs
2021-10-11T13:26:34.579Z INFO service ipfs-cluster-service/daemon.go:233 Datastore backend: badger
2021-10-11T13:26:34.592Z DEBUG cluster ipfs-cluster@v0.14.1/clusterhost.go:146 enabling DHT record persistence to datastore
2021-10-11T13:26:34.594Z DEBUG service ipfs-cluster-service/daemon.go:126 Configuration:
"cluster": {
"id": "",
"peername": "Cluster-India",
"private_key": "XXX_hidden_XXX",
"secret": "XXX_hidden_XXX",
"leave_on_shutdown": false,
"listen_multiaddress": [
"/ip4/0.0.0.0/tcp/9096",
"/ip4/0.0.0.0/udp/9096/quic"
"enable_relay_hop": true,
"connection_manager": {
"high_water": 400,
"low_water": 100,
"grace_period": "2m0s"
"dial_peer_timeout": "3s",
"state_sync_interval": "5m0s",
"pin_recover_interval": "12m0s",
"replication_factor_min": -1,
"replication_factor_max": -1,
"monitor_ping_interval": "15s",
"peer_watch_interval": "5s",
"mdns_interval": "10s",
"disable_repinning": true,
"follower_mode": false,
"peerstore_file": "",
"peer_addresses": []
"consensus": {
"crdt": {
"cluster_name": "ipfs-cluster",
"trusted_peers": [
"batching": {
"max_batch_size": 0,
"max_batch_age": "0s"
"rebroadcast_interval": "",
"peerset_metric": "",
"datastore_namespace": ""
"raft": {
"data_folder": "",
"init_peerset": [],
"wait_for_leader_timeout": "15s",
"network_timeout": "10s",
"commit_retries": 1,
"commit_retry_delay": "200ms",
"backups_rotate": 6,
"datastore_namespace": "",
"heartbeat_timeout": "1s",
"election_timeout": "1s",
"commit_timeout": "50ms",
"max_append_entries": 64,
"trailing_logs": 10240,
"snapshot_interval": "2m0s",
"snapshot_threshold": 8192,
"leader_lease_timeout": "500ms"
"api": {
"ipfsproxy": {
"listen_multiaddress": "/ip4/127.0.0.1/tcp/9095",
"node_multiaddress": "/ip4/127.0.0.1/tcp/5001",
"node_https": false,
"log_file": "",
"read_timeout": "0s",
"read_header_timeout": "5s",
"write_timeout": "0s",
"idle_timeout": "1m0s",
"max_header_bytes": 4096,
"extract_headers_extra": null,
"extract_headers_path": "",
"extract_headers_ttl": ""
"restapi": {
"http_listen_multiaddress": "/ip4/127.0.0.1/tcp/9094",
"ssl_cert_file": "",
"ssl_key_file": "",
"idle_timeout": "2m0s",
"libp2p_listen_multiaddress": null,
"id": "",
"basic_auth_credentials": "XXX_hidden_XXX",
"http_log_file": "",
"headers": {},
"cors_allowed_origins": [
"cors_allowed_methods": [
"GET"
"cors_allowed_headers": [],
"cors_exposed_headers": [
"Content-Type",
"X-Stream-Output",
"X-Chunked-Output",
"X-Content-Length"
"cors_allow_credentials": true,
"cors_max_age": "0s"
"ipfs_connector": {
"ipfshttp": {
"connect_swarms_delay": "30s",
"ipfs_request_timeout": "5m0s",
"pin_timeout": "2m0s",
"unpin_timeout": "3h0m0s",
"repogc_timeout": "24h0m0s",
"unpin_disable": false
"pin_tracker": {
"stateless": {
"max_pin_queue_size": 0,
"concurrent_pins": 10
"monitor": {
"pubsubmon": {
"check_interval": "15s",
"failure_threshold": 3
"informer": {
"disk": {
"metric_ttl": "30s",
"metric_type": "freespace"
"observations": {
"metrics": {
"enable_stats": false,
"prometheus_endpoint": "/ip4/127.0.0.1/tcp/8888",
"reporting_interval": "2s"
"tracing": {
"enable_tracing": false,
"jaeger_agent_endpoint": "/ip4/0.0.0.0/udp/6831",
"sampling_prob": 0.3,
"service_name": "cluster-daemon"
"datastore": {
"badger": {
"folder": "",
"gc_discard_ratio": 0.2,
"gc_interval": "15m0s",
"gc_sleep": "10s",
"badger_options": {
"dir": "",
"value_dir": "",
"sync_writes": true,
"table_loading_mode": 2,
"value_log_loading_mode": 0,
"num_versions_to_keep": 1,
"max_table_size": 16777216,
"level_size_multiplier": 10,
"max_levels": 7,
"value_threshold": 32,
"num_memtables": 5,
"num_level_zero_tables": 5,
"num_level_zero_tables_stall": 10,
"level_one_size": 268435456,
"value_log_file_size": 1073741823,
"value_log_max_entries": 1000000,
"num_compactors": 2,
"compact_l_0_on_close": false,
"read_only": false,
"truncate": true
"leveldb": {
"folder": "",
"leveldb_options": {
"block_cache_capacity": 0,
"block_cache_evict_removed": false,
"block_restart_interval": 0,
"block_size": 0,
"compaction_expand_limit_factor": 0,
"compaction_gp_overlaps_factor": 0,
"compaction_l0_trigger": 0,
"compaction_source_limit_factor": 0,
"compaction_table_size": 0,
"compaction_table_size_multiplier": 0,
"compaction_table_size_multiplier_per_level": null,
"compaction_total_size": 0,
"compaction_total_size_multiplier": 0,
"compaction_total_size_multiplier_per_level": null,
"compression": 0,
"disable_buffer_pool": false,
"disable_block_cache": false,
"disable_compaction_backoff": false,
"disable_large_batch_transaction": false,
"iterator_sampling_rate": 0,
"no_sync": false,
"no_write_merge": false,
"open_files_cache_capacity": 0,
"read_only": false,
"strict": 0,
"write_buffer": 0,
"write_l0_pause_trigger": 0,
"write_l0_slowdown_trigger": 0
2021-10-11T13:26:34.616Z DEBUG service ipfs-cluster-service/daemon.go:189 stateless pintracker loaded
2021-10-11T13:26:34.617Z INFO cluster ipfs-cluster@v0.14.1/cluster.go:134 IPFS Cluster v0.14.1 listening on:
/ip4/[this node]/tcp/9096/p2p/12D3KooWQ8Nzex9svhaP6aGRvddMKs4BT9BVViibmEAZnh8GvdSi
/ip4/127.0.0.1/tcp/9096/p2p/12D3KooWQ8Nzex9svhaP6aGRvddMKs4BT9BVViibmEAZnh8GvdSi
2021-10-11T13:26:34.617Z DEBUG pstoremgr pstoremgr/pstoremgr.go:102 adding peer address /ip4/[Node0]/tcp/9096/p2p/12D3KooWRVXuczRAT4LCdtWK6GP1f2dVBBxSXQtxs3TVSc9YbdVb
2021-10-11T13:26:34.625Z DEBUG pstoremgr pstoremgr/pstoremgr.go:324 connecting to 12D3KooWRVXuczRAT4LCdtWK6GP1f2dVBBxSXQtxs3TVSc9YbdVb
2021-10-11T13:26:37.626Z DEBUG pstoremgr pstoremgr/pstoremgr.go:327 context deadline exceeded
2021-10-11T13:26:37.627Z DEBUG pstoremgr pstoremgr/pstoremgr.go:324 connecting to 12D3KooWQ8Nzex9svhaP6aGRvddMKs4BT9BVViibmEAZnh8GvdSi
2021-10-11T13:26:37.627Z DEBUG pstoremgr pstoremgr/pstoremgr.go:327 dial to self attempted
2021-10-11T13:26:37.627Z DEBUG cluster ipfs-cluster@v0.14.1/cluster.go:182 bootstrap count 0
2021-10-11T13:26:37.628Z INFO service ipfs-cluster-service/daemon.go:218 Bootstrapping to /ip4/[Node0]/tcp/9096/p2p/12D3KooWRVXuczRAT4LCdtWK6GP1f2dVBBxSXQtxs3TVSc9YbdVb
2021-10-11T13:26:37.628Z DEBUG cluster ipfs-cluster@v0.14.1/cluster.go:930 Join(/ip4/[Node0]/tcp/9096/p2p/12D3KooWRVXuczRAT4LCdtWK6GP1f2dVBBxSXQtxs3TVSc9YbdVb)
2021-10-11T13:26:37.628Z DEBUG pstoremgr pstoremgr/pstoremgr.go:102 adding peer address /ip4/[Node0]/tcp/9096/p2p/12D3KooWRVXuczRAT4LCdtWK6GP1f2dVBBxSXQtxs3TVSc9YbdVb
2021-10-11T13:26:37.628Z INFO restapi rest/restapi.go:549 REST API (HTTP): /ip4/127.0.0.1/tcp/9094
2021-10-11T13:26:37.628Z INFO ipfsproxy ipfsproxy/ipfsproxy.go:317 IPFS Proxy: /ip4/127.0.0.1/tcp/9095 -> /ip4/127.0.0.1/tcp/5001
2021-10-11T13:26:37.628Z INFO crdt go-ds-crdt@v0.1.22/crdt.go:278 crdt Datastore created. Number of heads: 0. Current max-height: 0
2021-10-11T13:26:37.628Z INFO crdt crdt/consensus.go:300 'trust all' mode enabled. Any peer in the cluster can modify the pinset.
2021-10-11T13:26:37.629Z INFO cluster ipfs-cluster@v0.14.1/cluster.go:656 Cluster Peers (without including ourselves):
2021-10-11T13:26:37.629Z INFO cluster ipfs-cluster@v0.14.1/cluster.go:658 - No other peers
2021-10-11T13:26:37.629Z INFO cluster ipfs-cluster@v0.14.1/cluster.go:671 ** IPFS Cluster is READY **
2021-10-11T13:26:37.629Z DEBUG cluster ipfs-cluster@v0.14.1/cluster.go:270 auto-triggering RecoverAllLocal()
2021-10-11T13:26:40.628Z ERROR p2p-gorpc go-libp2p-gorpc@v0.1.3/call.go:63 context deadline exceeded
2021-10-11T13:26:40.628Z ERROR cluster ipfs-cluster@v0.14.1/cluster.go:954 context deadline exceeded
2021-10-11T13:26:40.628Z ERROR service ipfs-cluster-service/daemon.go:221 bootstrap to /ip4/[Node0]/tcp/9096/p2p/12D3KooWRVXuczRAT4LCdtWK6GP1f2dVBBxSXQtxs3TVSc9YbdVb failed: context deadline exceeded
2021-10-11T13:27:07.630Z DEBUG pstoremgr pstoremgr/pstoremgr.go:324 connecting to 12D3KooWRVXuczRAT4LCdtWK6GP1f2dVBBxSXQtxs3TVSc9YbdVb
2021-10-11T13:27:07.891Z DEBUG pstoremgr pstoremgr/pstoremgr.go:327 failed to dial 12D3KooWRVXuczRAT4LCdtWK6GP1f2dVBBxSXQtxs3TVSc9YbdVb:
* [/ip4/[Node0]/tcp/9096] failed to negotiate security protocol: read tcp4 [this node]:9096->[Node0]:9096: read: connection reset by peer
2021-10-11T13:27:07.892Z DEBUG pstoremgr pstoremgr/pstoremgr.go:324 connecting to 12D3KooWQ8Nzex9svhaP6aGRvddMKs4BT9BVViibmEAZnh8GvdSi
2021-10-11T13:27:07.892Z DEBUG pstoremgr pstoremgr/pstoremgr.go:327 dial to self attempted
2021-10-11T13:27:37.629Z DEBUG pstoremgr pstoremgr/pstoremgr.go:324 connecting to 12D3KooWRVXuczRAT4LCdtWK6GP1f2dVBBxSXQtxs3TVSc9YbdVb
2021-10-11T13:27:37.891Z DEBUG pstoremgr pstoremgr/pstoremgr.go:327 failed to dial 12D3KooWRVXuczRAT4LCdtWK6GP1f2dVBBxSXQtxs3TVSc9YbdVb:
* [/ip4/[Node0]/tcp/9096] failed to negotiate security protocol: message did not have trailing newline
…and then it continues to “dial to self attempted”
