I have two running IPFS daemons on two Raspberry Pis with Raspbian in the same subnet. I followed the inctructions (https://cluster.ipfs.io/documentation) and successfully set up a IPFS cluster with a fixed peerset. With “ipfs-cluster-ctl peers ls” i can see both peers. The problem is that the peers dont sync their pins. I successfully pinned both peers with “ipfs-cluster-ctl pin add CID” but at they never finished pinning their files.
“ipfs-cluster-ctl status” still shows:
CID1:
Peer CID1: PINNING | 2018-07-21T08:25:01Z
Peer CID2: PINNING | 2018-07-21T08:33:35Z
CID2:
“ipfs-cluster-ctl pin ls”
CID1| | Repl. Factor: -1 | Allocations: [everywhere]
CID2| | Repl. Factor: -1 | Allocations: [everywhere]
I tried:
- restarted all daemons and even the Pis
- removed all pins and pinned new files on both ipfs daemons
- set up a cluster via bootstrap
but the result was the same.
“ipfs pin ls” still shows nothing on the second peer.
Im not sure if this is a bug or im doing something wrong :-/.
update: I had to pin the files with “ipfs-cluster-ctl pin add HASH” and not the peers. I thought the cluster would auto sync everything.
