For some reason, the 5001 port on my ipfs node doesnt respond to requests
uploads to this endpoint wait indefinitely and only go through when i restart the ipfs service
i see this log as well
websocket: failed to close network connection:
Which version of Kubo are you running?
If you run ipfs id while the node is running what do you get?
It’s pretty normal to see these websocket errors btw.
