I’m running ipfs pin add bafybeifn7mfodhprlrd4fy6y2robhh2ksztyp7te6ecfw7am6bpxopsyma
and it’s stuck there for like hours.
Is there a way to configure a timeout on IPFS node?
This is golang code and like almost all golang codes this uses context.Context propagation, that means you can CTRL + C, kill, … your CLI, this is gonna create an HTTP connection error which will be propagated and the pin will stop.
example using timeout:
$ timeout 5m ipfs pin add Qmfoo
You can also see what CID it is stuck with watch ipfs stats bitswap
Thanks so much for replying all my posts. Yesterday I’ve been running lots of pin add bafyxxxxx and all seems fine.
But today, I ran the below and keep getting timeouts.
Error: context canceled
Timeout occurred for CID bafybeifjtfsgtybrswrwmzntqgoo73stdbzit5ixucwvvr4a34ed5i5cve.
Timeout occurred for CID bafybeibfiyxncl3bjbg3xhk3ou34xc4kz5wpinwyiy7gmmvue63mcbk4su.
Timeout occurred for CID bafybeifxbu4pahpi7bftjgjzewmpsextqllpocyvhg3fkacf5nseizdj4i.
Timeout occurred for CID bafybeiayc5cvaskp5ibs7xqlu4akqaghpzzpq55epxrynhfq5y6znqreja.
Timeout occurred for CID bafybeieseea5bfcayfpmkcb4rqqxi6ntt2gyinxqiu3ds7nwtksk4oixii.
Timeout occurred for CID bafybeic6c3eo3ocllwtbngrjqo2ijo2nkbyet2xoyszgtzkj3qchljmkdi.
Timeout occurred for CID bafybeiah5a2cnbdzovnbd5pxvlc5uptj75gowl24nizwqfpbbzrcajwsia.
Timeout occurred for CID bafybeiepgnbenmcfrwmlilpe34h63bqyeqdcm7i6lwvay5meric2avkf5u.
How to resolve this? I’ve restarted by daemon and added DHT too.
It seems to be working now. But why i can’t pin some CIDs while the CIDs are there on IPFS network?
