I am using a CentOS 7 virtualbox VM to run my build,following is the steps show in my terminal window:
I do try to traverse the firewall in front of me to touch ipfs.io, it seems work.
And I follow the guide from the https://github.com/ipfs/go-ipfs, especially the segment of “Install”->“Build from Source”.Then I got a lot of “timed out”, “read only access”.
I even change the IPFS_API to see if something improved.(Thank stebalien’s hint in another dissus.)
It seems that I can’t get all the dependencies needed, Can anyone help me ? Thank you very much! Any info is welcome.
