¿It's possible to upload a php script and host it on IPFS? FTP Access
Hi my issue is if this is possible. I wanna create a platform on IPFS using a Laravel PHP script. Im not so sure if this gonna work, but im trying to upload the complete folder and then install it with a normal MySQL database. The other question i had if it’s possible to have FTP access to upload files to IPFS.
I hoppe you answer my issues
I wait for the answers
Thanks
Laravel PHP is an MVC that requires a live server and data backend.
You need a static site generator, such as Gatsby (there are many others):
https://staticsitegenerators.net/
There are ways to make Single Page Applications (in JS) that are static sites but act like MVC or similar sites.
One example is https://tiddlywiki.com/
Probably the most popular is AngularJS
Others written in Smalltalk that compile or interpret into JS:
https://www.amber-lang.net/
https://pharojs.github.io/
You can see on https://staticsitegenerators.net/ that there are several PHP-based Static Site Generators.
some that are still actively updated:
The most popular by far is
  • I’d say that is your best bet.
