Do you have solution for netlify to do IPFS upload into my own node after build is done?
Uniswap has code to do that with Pinata: interface/release.yaml at main · Uniswap/interface · GitHub
Web3.storage also have an action: GitHub - web3-storage/add-to-web3: ⁂ Github Action to upload your website to web3.storage
To your own node you would need to recreate something similar.
- add a way to auth you (a reverse proxy that check Bearer tokens for example).
- Upload, probably with auspinner or by doing
ipfs dag import(rather the matching API call) on the remote node
