System: MacOS 10.13.03
I’ve downloaded IPFS to my downloads folder. It seems to unzip “automagically”. I’ve tried dragging both IPFS and install.sh to my applications folder and then run install.sh from command line. However, that doesn’t yield the desired result (command not found).
What am I doing wrong? Apologies for the level of the question. I realize this software is probably a bit to advanced for me, but my curiousity got the best of me.
Maybe it’s better to try out https://github.com/ipfs-shipyard/ipfs-desktop which is a desktop application for running a IPFS node. Should be a lot easier to get up and running with.
Weird, installation went fine (After trusting the developer).
I launch the program
The IPFS icon briefly appears
And then disappears.
It is visible in activity monitor
But I can’t switch to it when hitting cmd tab.
Hello! Hope you enjoy using IPFS Desktop. When you launch it, it will just start running the Menubar application. Thus, you need to click on the status icon to open it.
