Port already in use
I am just starting to learn about IPFS. Was trying to rum ipfs daemon command and it is saying port 8080 already in use.
Please help in which property/config while I canchange this 8080 port to any other port.
Thanks
Sweta Kedia
hi,
maybe that can help : https://ipfs.io/docs/commands/#ipfs-config
Similar problem was discussed at here.
If you want to change IPFS gateway port from 8080 to something else (8081), you can do it via:
ipfs config Addresses.Gateway /ip4/0.0.0.0/tcp/8081
+ daemon restart.
