Hi!
I would like to know if someone use the Sickrage (SiCKRAGE · GitHub) and is It possible create an integration with IPFS?
Did anyone do something like this? Is it sense?
Hi!
I don’t know Sickrage nor WatchIt, but they seem to want to achieve the same goals. WatchIt looks newer (aka less mature) but is designed on top of IPFS directly. Its development looks active. I never used one or the other, though.
Thank you!!!
I’ll try the watchit-desktop
