Solved: IPFS doesn't pin anymore [ignore, solved]
I used to be able to pin to IPFS and view it in Brave Browser, but now I can’t.
I now tried a basic text file with this:
ipfs add example.txt
[get a CID]
ipfs pin add [CID]
But it won’t show up on 2 different VPS
is your node online ?
you need to run ipfs daemon too.
If it is then you can check Diagnostic tools | IPFS Docs
solved it with a restart., thanks
