Subdomain gateway behind Caddy
I’m trying to set up a subdomain IPFS gateway with Kubo. Everything runs behind a Caddy reverse proxy. The problem is that every CID, despite resolving via ipfs.v1rtl.site/ipfs/<cid> and being pinned, it returns 404.
$ curl https://bafybeieenkchlv6s5zaxr2tjnuxtufihlmpfo4u2xp5hf4a4lsxsizuo5q.ipfs.v1rtl.site
404 page not found
This is my Caddyfile:
ipfs.v1rtl.site {
        tls /etc/caddy/ssl/ipfs.v1rtl.site/fullchain.pem /etc/caddy/ssl/ipfs.v1rtl.site/privkey.pem
        reverse_proxy :8080
*.ipfs.v1rtl.site {
        reverse_proxy :8080
I have also enabled subdomain gateways through Kubo config in ~/.ipfs/config:
// rest config
  "Gateway": {
    "HTTPHeaders": {},
    "RootRedirect": "",
    "NoFetch": false,
    "NoDNSLink": false,
    "DeserializedResponses": null,
    "DisableHTMLErrors": null,
    "PublicGateways": {
        "ipfs.v1rtl.site": {
                "UseSubdomains": true
But then /ipfs/<cid> stops working. Can I make only subdomain gateway work somehow?
Try adding the "Paths" config option as follows:
// rest config
  "Gateway": {
    "HTTPHeaders": {},
    "RootRedirect": "",
    "NoFetch": false,
    "NoDNSLink": false,
    "DeserializedResponses": true,
    "PublicGateways": {
                "Paths": ["/ipfs", "/ipns"]
That 404 you are getting is probably from Caddy (based on the fact it’s http/2, whereas Kubo is http/1.1).
Try adding the global debug to your Caddyfile:
	debug
ipfs.v1rtl.site {
        reverse_proxy :8080
*.ipfs.v1rtl.site {
        reverse_proxy :8080
And sharing the logs
Hm… I think the Kubo config has redundant ipfs..
Subdomain mode implies {cid}.ipfs. and {id}.ipns. will be used anyway, as a way of accessing every enabled namespace.
So for config with expliciut ipfs.v1rtl.site, the subdomain URL would have .ipfs.ipfs: https://bafybeieenkchlv6s5zaxr2tjnuxtufihlmpfo4u2xp5hf4a4lsxsizuo5q.ipfs.ipfs.v1rtl.site/ whichis likely not what you want.
To fix it, and only have one .ipfs. subdomain, try updating Kubo config to not have ipfs.:
- "ipfs.v1rtl.site": {
+ "v1rtl.site": {
Then Kubo’s handling of Host header when processing https://bafybeieenkchlv6s5zaxr2tjnuxtufihlmpfo4u2xp5hf4a4lsxsizuo5q.ipfs.v1rtl.site/ will work as expected.
