Unable to start ipfs daemon after reboot
I have restartted my linux machine which contains ipfs after that the ipfs is not starting what can i do now?
root@localhost:~# ipfs daemon
Initializing daemon…
go-ipfs version: 0.7.0-ea77213e3
Repo version: 10
System version: amd64/linux
Golang version: go1.14.9
Swarm listening on /ip4/127.0.0.1/udp/4001/quic
Swarm listening on /ip4/139.162.63.180/tcp/4001
Swarm listening on /ip4/139.162.63.180/udp/4001/quic
Swarm listening on /ip6/2400:8901::f03c:92ff:fe30:f6ef/tcp/4001
Swarm listening on /ip6/2400:8901::f03c:92ff:fe30:f6ef/udp/4001/quic
Swarm listening on /ip6/::1/udp/4001/quic
Swarm announcing /ip4/127.0.0.1/udp/4001/quic
Swarm announcing /ip4/139.162.63.180/tcp/4001
Swarm announcing /ip4/139.162.63.180/udp/4001/quic
Swarm announcing /ip6/::1/udp/4001/quic
API server listening on /ip4/0.0.0.0/tcp/5001
WebUI: http://0.0.0.0:5001/webui
Error: serveHTTPGateway: manet.Listen(/ip6/::ffff:139.162.63.180/tcp/8080) failed: listen tcp6: address ::ffff:139.162.63.180: no suitable address found
It looks like your IPFS config has some problem.
If you don’t mind to lose the data, just delete ~/.ipfs and than reinit and runs ipfs daemon.
It worked but now it is fine but later it is not going to fine how ever can you help me to solve this?How do i see my ipfs gatewaty - #10 by ipfsme
