I am new to IPFS.According to the documentation, i downloaded the ipfs and put the folder in the environment variable.
I then ran “ipfs init”.
C:\Users\mitesh pandey>ipfs init
initializing IPFS node at C:\Users\mitesh pandey\.ipfs
generating 2048-bit RSA keypair...done
peer identity: QmQwkkF3rgEaDk24BacYYRTdmWwavgnMehbaDwbbJqgnZ7
to get started, enter:
ipfs cat /ipfs/QmS4ustL54uo8FzR9455qaxZwuMiUhyvMcX9Ba8nUH4uVv/readme
Then I ran ipfs daemon command and i got the following:
$ ipfs daemon
Initializing daemon…
go-ipfs version: 0.4.21-
Repo version: 7
System version: amd64/windows
Golang version: go1.12.5
Swarm listening on /ip4/10.100.58.42/tcp/4001
Swarm listening on /ip4/169.254.111.48/tcp/4001
Swarm listening on /ip4/169.254.31.223/tcp/4001
Swarm listening on /ip4/169.254.36.107/tcp/4001
Swarm listening on /ip4/192.168.137.1/tcp/4001
Swarm listening on /ip4/192.168.253.1/tcp/4001
Swarm listening on /ip4/192.168.56.1/tcp/4001
Swarm announcing /ip4/10.100.58.42/tcp/4001
Swarm announcing /ip4/169.254.111.48/tcp/4001
Swarm announcing /ip4/169.254.31.223/tcp/4001
Swarm announcing /ip4/169.254.36.107/tcp/4001
Swarm announcing /ip4/192.168.137.1/tcp/4001
Swarm announcing /ip4/192.168.253.1/tcp/4001
Swarm announcing /ip4/192.168.56.1/tcp/4001
WebUI: http://127.0.0.1:5001/webui
Gateway (readonly) server listening on /ip4/127.0.0.1/tcp/8080
Daemon is ready -
Now when i try to visit http://127.0.0.1:5001/webui
It runs forever telling waiting for 127.0.0.1 -
Also when i try to run ipfs swarm peers , I get empty.
I searched this issue online and i found the problem in the github issue but didn’t find the solution.
Note: I have disabled my antivirus.
Also i am also on the network of a university. I am currently residing in the university dorm.
