I’m running ipfs/go-ipfs:v0.12.0 using docker-compose. I also populated the environment variable “CLUSTER_SECRET” per snippet below. What I’m wondering is why I’m still seeing the warning message like “Cluster secret is empty, cluster will start on unprotected network” in the log file? Do I need to set anything else to make ipfs-cluster takes the cluster secret?
cluster0:
container_name: cluster0
restart: always
image: ipfs/ipfs-cluster:v0.14.5
depends_on:
- ipfs0
environment:
DUMMY: 012
PROJECT: ${PROJECT}
CLUSTER_PEERNAME: ${INSTANCE}
CLUSTER_IPFSHTTP_NODEMULTIADDRESS: /dns4/ipfs0/tcp/5001
CLUSTER_CRDT_TRUSTEDPEERS: '*' # Trust all peers in Cluster
CLUSTER_MONITORPINGINTERVAL: 2s # Speed up peer discovery
CLUSTER_IPFSPROXY_NODEMULTIADDRESS: /dns4/ipfs0/tcp/5001 # Make IPFS Proxy work
CLUSTER_IPFSPROXY_LISTENMULTIADDRESS: /ip4/0.0.0.0/tcp/9095 # Expose IPFS Proxy API
CLUSTER_RESTAPI_HTTPLISTENMULTIADDRESS: /ip4/0.0.0.0/tcp/9094 # Expose Rest API
CLUSTER_SECRET_FILE: /run/secrets/ipfs_cluster_secret
CLUSTER_SECRET: ${IPFS_CLUSTER_SECRET_KEY}
secrets:
- ipfs_cluster_secret
ports:
# Open API port (allows ipfs-cluster-ctl usage on host)
- "9094:9094"
# IPFS Proxy port
# Can be load-balanced.
- "9095:9095"
# The cluster swarm port would need to be exposed if this container
# was to connect to cluster peers on other hosts.
- "9096:9096" # Cluster IPFS Proxy endpoint
volumes:
- ${DATA_DIR}/ipfs-cluster:/data/ipfs-cluster
- ${DATA_DIR}/configs/ipfs-start.bash:/scripts/ipfs-start.bash
- ${DATA_DIR}/configs/peers-tables.cfg:/scripts/peers-tables.cfg
entrypoint: ["/sbin/tini", "--"]
command: |-
sh -c '
Regards,
James
