i ran ipfs daemon in Termux.
How much bandwidth will it cost when sitting idle?
I have 2GB per day maximum allowance.
Not too much, if however you disable reproviding and the different servers which may route through your node if left on. Maybe the lowpower and announce-off profiles are a good starting point.
Until then I’d keep a close eye on the consumption.
By default Kubo will act as Amino DHT server and a limited relay if it has a public multiaddr. This may produce some ambient traffic as other peers will connect to you and store provider records or relay some data for hole punching.
Since you have only 2GiB limit, you may want to disable these features:
Routing.Type=autoclientSwarm.RelayService.Enabled=falsebut if I don’t host anything why and what would any server route through my node?
as far as I understand my idle node will just share DHTs which should not be much.
2. will I contribute anything to ipfs if my nose is always online but I don’t share any files myself or access any files?
