Can i start IPFS daemon without repo?
Can i use online mode of IPFS without creating repo via ipfs init? That is, can ipfs retrieve objects or blocks without caching or distributing them?
Not at the moment but you can use https://github.com/ipfs/ipget/.
Thanks for the answer! This is planed? And another question: are exists standalone tool for set object and get peers in swarm or how i can do that?
This is planed?
The plan is to continue supporting ipget.
I’m not sure I understand what you’re trying to do here.
Currently i need one function in IPFS: getting peers in my swarm (ipfs swarm peers). So, if cant start daemon with in-memory mode, i need to know, can i do it without modifying the code?
Unfortunately, you can’t.
A couple of workarounds I think you could do:
  • If you know the address of just one of the peers in the swarm and it API is listening other than on localhost, use ipfs --api /ip4/<ip address>/tcp/5001 swarm peers. If it’s only listening on localhost, use ssh to port-forward port 5001 and use /ip4/127.0.0.1/tcp/5001 (or even just curl http://<ip address>:5001/api/v0/swarm/peers, no ipfs binary needed).
  • Otherwise, you could initialize a repo on a ramdisk.
