Discussion: Identity, Revocation and Node Roles in Private IPFS Networks
We’ve been working with private IPFS deployments and repeatedly encounter operational challenges that are difficult to solve with the current swarm.key mechanism.
Today, swarm.key provides network isolation, which is extremely useful, but all participating nodes are effectively treated the same once they possess the key.
In practice, we’ve seen use cases where operators would benefit from additional controls such as:
  • Identifying specific nodes within a private swarm
  • Rotating access credentials without recreating the network
  • Revoking a compromised node without rotating the entire swarm key
  • Assigning different roles to different nodes (storage, gateway, accelerator, operator, etc.)
  • Applying different policies depending on node type
  • Supporting enterprise or B2B environments where participation needs to be managed more explicitly
  • Declare geographical zone for regulation
Some examples we’ve encountered include:
  • Private CDN-like deployments built on IPFS
  • Enterprise storage clusters
  • Customer-operated nodes participating in a managed private swarm
  • Multi-tenant environments where different organizations share infrastructure
I’m curious how others are handling these scenarios today.
Questions for the community:
  1. Are you running private IPFS networks in production?
  2. Have you encountered limitations with the current swarm.key model?
  3. How do you currently handle node identification and access management?
  4. Would revocation or key rotation capabilities be useful in your deployments?
  5. Would role-based participation (e.g. storage node vs gateway node) solve any operational challenges you face?
Interested to hear how others are approaching this problem and whether there are existing solutions or design patterns that we may have missed.
Thanks for the help & feedback :folded_hands:
We’ve run private IPFS environments internally and this is probably the biggest limitation we’ve encountered. Once a node has the swarm key, it’s effectively trusted forever unless you rotate the entire network.
Node revocation has been a recurring pain point for us, especially when infrastructure is managed by multiple teams. Being able to revoke a single node without impacting everyone else would be a huge operational improvement.
We hit this issue after onboarding external partners into a private swarm.
Everything worked well until we needed to remove one participant without disrupting everyone else.
At that point we realized how limited the current model is. A proper membership and revocation mechanism would have saved us a lot of headaches.
We’ve implemented an external PKI layer on top of IPFS because swarm.key doesn’t provide enough granularity for production environments.
Each node receives its own certificate and we maintain a separate allowlist service to determine which peers should be trusted.
At that point swarm.key is really only providing network isolation while all actual identity management happens outside of IPFS.
It would be interesting to see a future swarm architecture where peer identity, credential rotation, revocation and policy enforcement are first-class concepts instead of external systems bolted on top.
We actually ran into something similar while experimenting with private IPFS for AI dataset distribution :robot:
Training clusters, inference clusters and archival storage nodes all had different responsibilities, but from the swarm’s perspective they’re basically all peers once they have the key :sweat_smile:
We ended up building additional control layers outside IPFS to manage access and permissions.
Would love to see a v2 private swarm model with identities, roles and credential rotation built in :folded_hands:
The additional control you mentioned around geographical zones and regulatory requirements would solve a real problem for us…
Some of our customers require guarantees that their data remains within specific jurisdictions due to GDPR, data sovereignty requirements, or contractual obligations. Having a way to identify and group nodes by region within the same private swarm would make it much easier to provide those guarantees while keeping a unified network architecture. For now, this limitation prevents us from considering private IPFS networks for some production environments
How do you envision these declarations working?
Could they be verified or certified in some way?
Happy to discuss further and share thoughts, I saw you shared it in the discord, I’ll send you a DM !
We’ve run into this on a local private deployment on our side also.
Sometimes the issue is not about security at all, it’s just purely operational. For example, 1 node has poor performance, creates noise in the network, and we’d like to revoke only that node from the swarm and not impact all the network for this revocation.
With this current model, it seems harder than it should be… So node revocation would be a really valuable improvement from our perspective.
It’s a very good idea. A private swarm probably needs a bit more than just isolation from my perspective. In real use, it’s often important to know which node is which, be able to disable one bad node if needed, and avoid rotating access for others just because one of them has an issue in his running. That feels especially relevant in company setup, where not every node should be treated the same way. This optimization could be a huge plus for complex architecture.
If you have a known set of nodes, can you agree in the network (e.g. in the ipfs-cluster) to not discover nodes but have an explicit list of peers in the ipfs and/or ipfs-cluster config (service.json) ? This way, you could exclude nodes if everyone agrees on it or did I misunderstand the issue?
