Consider this command
ipfs object get $(echo -n 'hello world' | ipfs add | awk '{print $2}')
So we’re just adding ‘hello world’ to the merkle DAG and then getting the associated object. It defaults to json encoding, so the command returns this:
{"Links":[],"Data":"\u0008\u0002\u0012\u000bhello world\u0018\u000b"}
We can use the --encoding protobuf option to disable json and give the result in a binary format, which produces several characters on my termal that this forum cannot display.
I assume that if I hash this binary value via sha2-256 and then encode that into base58, I ought to get the same string that ipfs add wrote to stdout (Qmf412jQZiuVUtdgnB36FXFX7xg5V6KEbSJ4dpQuhkLyfD).
But I have tried this (https://gist.github.com/MatrixManAtYrService/fa384d0d524c68d6c903e2be281eb672) and I get a different hash (QmXLUHrka5FQ1ac7ooZAg8MyVcLnzj1GEY5rW92tQyGguq).
I can think of three explanations:
- something other than the ipfs object is being hashed
ipfs object getis writing more than just the object (a newline perhaps) and I’m failing to strip it - there’s some third encoding (not json or protobuf) that the hash is based on
Can somebody tell me which of the above is more likely? Thanks.
