From @MaxEntropyy on Tue Oct 27 2015 06:54:27 GMT+0000 (UTC)
Hello…
I have recently read the 2014 Filecoin paper and I understand from the IPFS website that the Filecoin release will follow the V1.0 release of IPFS. I am considering the use of IPFS and possibly Filecoin in a telco communications environment for a modified type of messaging; and for high latency network file stores.
Several questions come to mind…
Questions:
Q1: is there an implementation of the Filecoin system?
Q2: if so, then have there been any performance analysis tests run that you can publish for file size boundary cases?
Q3: I am interested in Proof of Retrievability Challenges… Is there a discussion of the different cases to be considered?
Q4: I have looked for an implementation of the Gateway.ipfs.io executable and I don’t believe it is at the IPFS Github repository. Did I miss it?
If there is a more appropriate place to ask these questions please direct me to that location.
With kind regards,
jds
Copied from original issue: https://github.com/ipfs/faq/issues/68
From @RichardLitt on Thu Mar 10 2016 18:59:04 GMT+0000 (UTC)
@MaxEntropyy Good questions. Sorry for the delay.
Q1/2. Not yet.
Q3. I think you might want to check github.com/ipfs/specs. There might be an answer in there. I’m personally not sure, at the moment
Q4. Yep: it is in go-ipfs, the current implementation.
This is the right place, but we have not been the most timely. IRC is always faster.
From @MaxEntropyy on Thu Mar 17 2016 05:50:50 GMT+0000 (UTC)
Thanks Richard
On Thu, Mar 10, 2016 at 1:59 PM Richard Littauer notifications@github.com
wrote:
@MaxEntropyy https://github.com/MaxEntropyy Good questions. Sorry for
the delay.
Q1/2. Not yet.
Q4. Yep: it is in go-ipfs <//github.com/ipfs/go-ipfs>, the current
implementation.
always faster.
Reply to this email directly or view it on GitHub
https://github.com/ipfs/faq/issues/68#issuecomment-195001378.
From @RichardLitt on Thu Mar 17 2016 14:28:52 GMT+0000 (UTC)
No problem. Reopen as needed.
