I first downloaded the IPFS Desktop companion and wanted to trial the Command-Line. This was my first command-line install and I think all went well, but I am having problem initializing the node from the terminal.
I checked that the bootstrap matches just as I was not sure if this issue is a communication problem between the command-line and Desktop version of something else
