What makes this different from proxy service approaches to the same problem is that the name and content layers are clearly separated, yet coordinated: the name and CID lookup happens at the DNS level, the IPFS content is served through a regular gateway, but both work seamlessly together from the user perspective.
(N.B.: If you don’t wish that your domain be served via the default EthDNS gateway, you can easily specify one of your choice via theArecord in ENS —though be aware, they must be running recent go-ipfs)
I read this as them having an IPFS gateway, all *.eth.link domains are routed via that unless you provide your own A record to set a different gateway. I don’t know what you need to provide in that record. DnsLink doesn’t use an A record : DNSLink Standard
If you find out, please do share here for others when they find this post and are in the same situation.
Have you thought that servers behind “eth.link” itself act as an IPFS gateway?
that’s a possible answer.
Is it the right one?
My test website http://rocinha.eth.link/ was down for four hours because of a “HTTP 502 Bad Gateway” error.
I need to understand whether EthLink is reliable or not to deploy a production website there. Or how to make it reliable. Or if it was a configuration problem of mine.
Unfortunately I didn’t find a way to contact them: https://eth.link/
Do you know how to contact them?
$ curl -v "http://rocinha.eth.link/"
* Trying 35.241.8.114...
* TCP_NODELAY set
* Connected to rocinha.eth.link (35.241.8.114) port 80 (#0)
> GET / HTTP/1.1
> Host: rocinha.eth.link
> User-Agent: Mozilla/5.0 (compatible; MSIE 9.0; Windows NT 6.1; Trident/5.0)
> Accept: */*
> Referer:
< HTTP/1.1 502 Bad Gateway
< Content-Type: text/html; charset=UTF-8
< Referrer-Policy: no-referrer
< Content-Length: 332
< Date: Tue, 14 Jul 2020 11:09:42 GMT
<html><head>
<meta http-equiv="content-type" content="text/html;charset=utf-8">
<title>502 Server Error</title>
</head>
<body text=#000000 bgcolor=#ffffff>
<h1>Error: Server Error</h1>
<h2>The server encountered a temporary error and could not complete your request.<p>Please try again in 30 seconds.</h2>
<h2></h2>
</body></html>
* Connection #0 to host rocinha.eth.link left intact
* Closing connection 0
