When trying to connect to a Kubo node using WebTransport, I discovered that my Kubo node is advertising the public mutiaddrs without the WebTransport certificate hash which means a browser cannot connect.
Weirdly, the Node’s private IPs have the certhash embedded in them.
For example, the following public IP multiaddr doesn’t have the certhash:
"/ip4/149.248.221.175/udp/4001/quic-v1/webtransport/p2p/12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh",
I suspect this is because the public IPv4 of the node is configured through AppendAnnounce in the config. Because the public IP is not “detectable” or known from the perspective of the Kubo container.
Is there a way to configure Kubo to announce the full WebTransport multiaddr for IPs provided through AppendAnnounce?
"ID": "12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh",
"PublicKey": "CAESIADglZ4MsCxjqM+GMrJ2Ofa7UOT2SFM8ejJfiIVIYY7i",
"Addresses": [
"/ip4/127.0.0.1/tcp/4001/p2p/12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh",
"/ip4/127.0.0.1/tcp/4002/ws/p2p/12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh",
"/ip4/127.0.0.1/udp/4001/quic-v1/p2p/12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh",
"/ip4/127.0.0.1/udp/4001/quic-v1/webtransport/certhash/uEiAKE86Eh0_yTbno_ir8HjjtlrGzSA72pY9P27HwfWOGmQ/certhash/uEiCw0HNHBC7bFagFL1yjD77RZkSvzs7PbkEkNfcU1-rfFg/p2p/12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh",
"/ip4/127.0.0.1/udp/4001/quic/p2p/12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh",
"/ip4/145.40.93.179/tcp/4001/p2p/12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh",
"/ip4/145.40.93.179/udp/4001/quic-v1/p2p/12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh",
"/ip4/145.40.93.179/udp/4001/quic/p2p/12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh",
"/ip4/149.248.221.175/tcp/4001/p2p/12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh",
"/ip4/149.248.221.175/udp/4001/quic-v1/p2p/12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh",
"/ip4/149.248.221.175/udp/4001/quic/p2p/12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh",
"/ip6/2604:1380:4091:360c:0:4:48a9:3/tcp/4001/p2p/12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh",
"/ip6/2604:1380:4091:360c:0:4:48a9:3/udp/4001/quic-v1/p2p/12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh",
"/ip6/::1/tcp/4001/p2p/12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh",
"/ip6/::1/tcp/4002/ws/p2p/12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh",
"/ip6/::1/udp/4001/quic-v1/p2p/12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh",
"/ip6/::1/udp/4001/quic-v1/webtransport/certhash/uEiAKE86Eh0_yTbno_ir8HjjtlrGzSA72pY9P27HwfWOGmQ/certhash/uEiCw0HNHBC7bFagFL1yjD77RZkSvzs7PbkEkNfcU1-rfFg/p2p/12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh"
"AgentVersion": "kubo/0.18.1/675f8bd/docker",
"Protocols": [
"/ipfs/bitswap",
"/ipfs/bitswap/1.0.0",
"/ipfs/bitswap/1.1.0",
"/ipfs/bitswap/1.2.0",
"/ipfs/id/1.0.0",
"/ipfs/id/push/1.0.0",
"/ipfs/lan/kad/1.0.0",
"/ipfs/ping/1.0.0",
"/libp2p/circuit/relay/0.1.0",
"/p2p/id/delta/1.0.0",
"/x/"
The node’s configuration:
"API": {
"HTTPHeaders": {}
"Addresses": {
"API": [
"/ip4/0.0.0.0/tcp/5001",
"/ip6/::/tcp/5001"
"Announce": [],
"AppendAnnounce": [
"/ip4/149.248.221.175/tcp/4001",
"/ip4/149.248.221.175/udp/4001/quic",
"/ip4/149.248.221.175/udp/4001/quic-v1",
"/ip4/149.248.221.175/udp/4001/quic-v1/webtransport"
"NoAnnounce": [
"/ip4/10.0.0.0/ipcidr/8",
"/ip4/100.64.0.0/ipcidr/10",
"/ip4/169.254.0.0/ipcidr/16",
"/ip4/172.16.0.0/ipcidr/12",
"/ip4/192.0.0.0/ipcidr/24",
"/ip4/192.0.2.0/ipcidr/24",
"/ip4/192.168.0.0/ipcidr/16",
"/ip4/198.18.0.0/ipcidr/15",
"/ip4/203.0.113.0/ipcidr/24",
"/ip4/240.0.0.0/ipcidr/4",
"/ip6/100::/ipcidr/64",
"/ip6/2001:2::/ipcidr/48",
"/ip6/2001:db8::/ipcidr/32",
"/ip6/fc00::/ipcidr/7",
"/ip6/fe80::/ipcidr/10"
"Swarm": [
"/ip4/0.0.0.0/tcp/4001",
"/ip4/0.0.0.0/tcp/4002/ws",
"/ip4/0.0.0.0/udp/4001/quic",
"/ip6/::/tcp/4001",
"/ip6/::/tcp/4002/ws",
"/ip6/::/udp/4001/quic-v1/webtransport",
"/ip6/::/udp/4001/quic-v1"
"AutoNAT": {
"ServiceMode": "disabled"
"Bootstrap": [
"/ip4/104.131.131.82/udp/4001/quic/p2p/QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ"
"DNS": {
"Resolvers": {}
"Datastore": {
"BloomFilterSize": 0,
"GCPeriod": "1h",
"HashOnRead": false,
"Spec": {
"mounts": [
"child": {
"path": "blocks",
"sync": true,
"type": "flatfs"
"mountpoint": "/blocks",
"prefix": "flatfs.datastore",
"type": "measure"
"child": {
"compression": "none",
"path": "datastore",
"type": "levelds"
"mountpoint": "/",
"type": "measure"
"type": "mount"
"StorageGCWatermark": 90,
"StorageMax": "10GB"
"Discovery": {
"MDNS": {
"Enabled": false
"Experimental": {
"FilestoreEnabled": false,
"GraphsyncEnabled": false,
"P2pHttpProxy": false,
"StrategicProviding": false,
"UrlstoreEnabled": false
"Gateway": {
"APICommands": [],
"HTTPHeaders": {
"X-Requested-With",
"Range",
"User-Agent"
"GET"
"NoDNSLink": false,
"NoFetch": false,
"PathPrefixes": [],
"PublicGateways": null,
"RootRedirect": "",
"Writable": false
"Identity": {
"PeerID": "12D3KooW9snnuzHgfzpBKWtZxU9tpPDqB7SG4qM9tGLA9eQgYpQh"
"Internal": {},
"Ipns": {
"RecordLifetime": "",
"RepublishPeriod": "",
"ResolveCacheSize": 128
"Migration": {
"DownloadSources": [],
"Keep": ""
"Mounts": {
"FuseAllowOther": false,
"IPFS": "/ipfs",
"IPNS": "/ipns"
"Peering": {
"Peers": null
"Pinning": {
"RemoteServices": {}
"Plugins": {
"Plugins": null
"Provider": {
"Strategy": ""
"Pubsub": {
"DisableSigning": false,
"Router": ""
"Reprovider": {},
"Routing": {
"Methods": null,
"Routers": null
"Swarm": {
"AddrFilters": [
"ConnMgr": {},
"DisableNatPortMap": true,
"EnableHolePunching": false,
"RelayClient": {
"Enabled": false
"RelayService": {},
"ResourceMgr": {
"MaxMemory": "1.8 GB"
"Transports": {
"Multiplexers": {},
"Network": {},
"Security": {}
