DAPP Developer, Web Designer needed, knowledge of IPFS and Cryptocurrencies required
We are looking for an experienced DAPP developer interested in making a positive impact on the media industry and all it affects. Build a new decentralized application using a smart contract to handle transactions from subscriber to content creator, based on a unique algorithm. The content needs to be hosted on an IPFS gateway, all accessed on a website which also needs modern design.
hello your porject is intresting do you have a github repositories to contribute ?
Thanks for your message.
There’s a beta site in need of redesign but it gives some idea how it works. http://beta.vettage.com
There’s also a White Paper and Deck at http://www.vettage.com
I’m not technical at all so I don’t really understand GitHub unfortunately, though I do have code ready to upload. Just not sure how. https://github.com/Vettages/VettageDev
All the Best
you need to do that :
if you need more details don’t hesitate.
Regards
No idea what Git Bash is. This tutorial assumes quite a lot without explanation.
Like I said, I’m not technical. I should not be doing any of this. I am a business owner looking to hire someone to do this work, in a timely manner, that I cannot do because I don’t have the skills, experience and knowledge or time to do so.
Is the plan to try to host all of your content on the public gateways or will you be setting up your own private gateways?
If public, there aren’t really any assurances that your content won’t be garbage collected – eventually making it unavailable unless someone else has it cached or pinned on their IPFS node(s).
