Galacteek 0.4.33 released
galacteek v0.4.33 was released, you can download it here
Release notes
You should update as this fixes a critical issue.
  • Disable pin-updates on syncing with all EDAGs as
    they would randomly block and keep the write-lock
    from being released
  • Bug fix when linking documents from the blog post editor
If you like we could work together on integrating this with qDesk.org and wrap it in Angular modules, then you could offer a “browser browser” and on any platform a pretty rich p2p message system plus all the other modules we are building/will build for it that might fit =)
Reach out if you’re interested!
Hello !
I’ve looked at qdesk downloaded it yesterday sounds really interesting congratulations ! I think integrating it with galacteek would be pretty awesome although i’m not exactly sure how that would be done. I’ll PM you to discuss it.
Thank you !
