Hi to all,
I have a server and wish to setup it as an IPFS node. Would you please help me in setting up a public IPFS gateway at a custom domain name ( for example “xxx.com/.../…” )?
Thanks in advance,
Hi to all,
Thanks in advance,
You’ll need to be more specific.
etc…
Thanks for your attention and sorry for not being clear enough.
Our server software is Ubunta 16.04
I didn’t get your idea by this question, but I want to setup this server as an IPFS node in order to share files and data with others. I mean putting files on our server and letting others to pick them through IPFS.
As I’m very new to IPFS, I have not any knowledge of how to do this. So I couldn’t try anything to be gotten stuck.
I would be so thankful to get help.
Please see the getting started documentation here: https://ipfs.io/ipfs/QmUfTfvwGCVa7j4H7m3zdadjPJHnt1f3NSeGuE5qDAcptj/docs/getting-started/
You can specify the gateway address using the Addresses.Gateway config option (see config.md in the source repo).
If you want to run the gateway under some path other than /, you’ll need to stick some reverse http proxy (e.g., nginx) out in front and have that rewrite the paths for you.
