hi,
Sorry if my question is very elementary.
Is it possible to set our private web server to act as a node for IPFS ( for example “myServer.com/…/…”? I mean is there any possibility for setting a server address for IPFS node in order to put files on server and share it with others?
(May be it is titled as “Setting up a public IPFS gateway at a custom domain name”
thanks in advance,
hi,
when we run your node with ipfs you have gateway enalbe aftr that locally you can define a DNS for that. for configure url in ipfs see config set manuals also.
Regards
Thanks a lot for your attention.
Do you have any clear example to show me how to do this?
I’m very confused about how doing this.
thanks
hi,
see that : http://ipfs.git.sexy/sketches/run_a_gateway.html for step ‘Next, modify your ipfs configuration’ see that
ipfs config edit - Opens the config file for editing in $EDITOR
DESCRIPTION:
To use 'ipfs config edit', you must have the $EDITOR environment
variable set to your preferred text editor.
Regards
