Hi @hector,
I am seeing a strange issue.
we had a setup where we have a single drive mounted to “/” [root] on /dev/sda on Linux operating system, everything was running fine, and was able to connect to a private IPFS-cluster containing 6 other nodes by setting cluster secret.
Now, I added a new disk /dev/sdb and mounted it to “/home/abc” and copied the exact configuration which was present before to “/home/abc”. But now, it’s unable to connect with the private network. Not sure why this is happening.
