galacteek v0.5.0 was just released, you can download it here
[0.5.0] - 2021-03-12
This release introduces support for remote pinning.
All IPFS services (pubsub, p2p) are now part of the application’s services graph (the application is now designed as a graph of services, you can view the graph in the Settings workspace).
Added
- Use go-ipfs version: 0.8.0
- Use PyQt version: 5.15.2
- Use PyQtWebEngine version: 5.15.2
- Support for remote pinning services (yay!)
- Configure your RPS from the settings (tested with Pinata)
- From the PIN object buttons (blue pin) you can choose to pin with a remote service or to your IPFS node
- Add a status icon for remote pinning (basic for now)
- Add a workspace action to view the application’s services graph (you need graphviz installed for this to work)
- Add coroutines to load services dynamically from the services Python package
Changed
- Support for mkdocs themes (bootswatch) for your dwebsites (darkly is the default)
- Easier to publish/unpublish websites, dynamic content … on your DID
- Easier to create and publish a markdown website
- QA toolbar: modernize, should now support large number of items
- Use a dock instead of a status bar
- MFS: recursive collapse when double-clicking an already-expanded directory
- Pubsub services are now part of the services tree
- P2P services (like the DIDauth service) are now part of the services tree
Fixed
- Fix mkdocs website creation on non-Linux platforms
- Focus bug in the markdown editor
